Hi Tom,
Nice work.  Lots of good info and tips starting to appear too.
Alan
On the subject of info, in my research of MTB ops I came across these pictures of MTB 250 in use during training of the Small Scale Raiding Force...
 The SSRF story is fascinating enough and the
page  I found the pictures on is a mine of info, but the interesting thing about the images are that they are the only ones of this type of MTB I've seen wearing the Admiralty Dark Scheme.
MTB250 was one of the Whites built boats, all but identical to the Italeri kit, note the windscreen on the bridge, ballistic padding around the wheelhouse and the pintle-mounted VGO guns, the pintles are mounted to the deck just inboard of the torpedo tubes, they aren't mounted on the torpedo tubes themselves.
There look to be some changes in the configuration of the mast but I can't make out the exact details.
Might make for an interesting paint-job and potential diorama!
One tip in the building process, I assembled the depth-charges in the kit and found the outer halves to be very poorly moulded, flash, mis-alignment and sink-marks aplenty, so I replaced them with 1/2" K&S brass tubing cut to 21mm lengths, the wall of the tubing is a little thin so a shim of thin plastic strip needs to be wrapped around each end piece to stop them dropping straight through but even so the result looks a lot better than the kit parts and a lot less work I think.
I'll post a few pics of my progress soon but I do plan to take my time with this kit so don't expect updates all that often.
