KitMaker: 2,531 posts
Posted: Sunday, February 12, 2012 - 08:27 AM UTC
Still need to build the bandstand and the splintermatresses.
Do any of you have an idea how to make them without useing a whole lot of magic sculp or milliput ? [Quote]
You might try laminating several pieces of thick plastic and then rounding the edges and corners with file and sand paper. I've done it to simulate stone work.
I used a round bit in a Dremel to further 'distress' the surface of the "blocks". Al
KitMaker: 14,499 posts
Posted: Sunday, February 12, 2012 - 09:51 AM UTC
Looking good Tom,
Re the band stand and matress. I have a feeling U Models will come up with something appropriate here. They have padding for the LCM 3 already.
You could make the stand from plastic card and a frame from brass rod.
'Action this Day'
Winston Spencer Churchill
Posted: Friday, February 17, 2012 - 11:36 PM UTC
Hi Tom,
Talking U Models, it might be worth contacting Rodolfe to see what he has in the pipe line.
Al, neat Maiale.
Alan
'Action this Day'
Zuid-Holland, Netherlands
KitMaker: 100 posts
Model Shipwrights: 99 posts
Posted: Saturday, February 18, 2012 - 07:50 AM UTC
I think i'll give it a try,the thick plasitc card for the splintermatresses.
Nice peace of stone masonry on that dio.
I'm not sure i can wait till he gets around to making the matresses.
In the mean time i've been working on the bridge/wheelhouse.
The oerlikon is also painted
I did do some work on the bandstand but that's no jet worth showing.
So till the next update.
TDK (tom)
chaos alway's win's,because it's better organized (terry pratchett)
Posted: Saturday, February 18, 2012 - 11:07 AM UTC
Good progress Tom, coming together really well.
'Action this Day'
KitMaker: 100 posts
Posted: Monday, February 20, 2012 - 07:31 AM UTC
Thanks AL,
Here are 2 photo's of the bandstand.
After this i'm going to give the matresses a try.
TDK
i also did some new antennas
Posted: Monday, February 20, 2012 - 07:34 AM UTC
'Action this Day'
KitMaker: 100 posts
Posted: Monday, February 20, 2012 - 08:14 AM UTC
plastic , just by accedent i got a piece of 1mm rod shaped almost perfect for it.
I just ran it between my nails like you do when you wrapping a present to make a nice curling string.
Posted: Monday, February 20, 2012 - 01:42 PM UTC
Hello Tom, You've really been making progress, and it looks terrific.
Viseu, Portugal
KitMaker: 51 posts
Model Shipwrights: 50 posts
Posted: Monday, February 20, 2012 - 07:45 PM UTC
One way to do matresses would be to use 'Das' modelling clay it air cures. put a Piece between two bits of wood (or whatever) the right thickness and width apart and roll it out like dough. Cut it to mattress length, smooth off the edges wrinkle or pleat with the side of a toothpick ....I've used Das for a cobble stone dock and even bow waves. Useful stuff.
Posted: Friday, February 24, 2012 - 07:07 AM UTC
Warning! There is a mistake in Step #19 of the instructions. It would have you install part 33E and two parts 10D upside down! It shows them with the slanted side up. They should be the other way around, flat side up. If you look at the photo of the turret on page 20 in the information booklet, you'll see the way they should be. I think they probably are steps used for climbing up into the turret. Al
KitMaker: 100 posts
Posted: Friday, February 24, 2012 - 07:54 AM UTC
some heavy metal for the Vosper and the PT518 whitch is also under construction.Be it that the vosper has priority.
Tonight the deck will go on forgood(i hope)
TDK
Posted: Saturday, February 25, 2012 - 07:33 PM UTC
Hi Tom,
Coming along really well, thanks for the update.
'Action this Day'
KitMaker: 100 posts
Posted: Tuesday, February 28, 2012 - 07:01 AM UTC
Just to give an impression of what it 's going to look like.
TDK
Posted: Tuesday, February 28, 2012 - 02:53 PM UTC
Looking real good Tom.
Posted: Wednesday, February 29, 2012 - 05:06 AM UTC
Hi Tom,
Great progress, enjoyed the build a lot, looking forward to the finished article.
'Action this Day'
Posted: Sunday, March 04, 2012 - 11:23 PM UTC
Hi Tom and Al,
Just a question about the upper foredeck. On the boats there seems to be two strips of anti slip walkway (if that's the correct term) , as shown on these two pics. Even on the boat with the dark upper deck this seems a different shade.
Is there a reason why you omitted this feature?
Understand that not all boats will have the same finish but the anit slip area seems to stand out or I would have though been made to stand out regardless of finish? Well if that makes any sense
Thanks for any thoughts.
'Action this Day'
KitMaker: 100 posts
Posted: Monday, March 05, 2012 - 01:09 AM UTC
Hi Al,
For me it's not clear if all had them antislip parts.
I did a lot of my detailing of a photo where it looks like there isn't antislip present.If that is thru i have a problem because i should have removed the lines on the fordeck.That is now impossible to do .
If i haven't looked close enough at that photo i'm going to give the aera a wash with a dark deckcolour mix to get the shade in.And then there is the white star recon sign that i have seen on 1 of the photo's ,it crosses the antislip aera but is it the same structure?So question questions.
TDK(Tom)
KitMaker: 127 posts
Model Shipwrights: 43 posts
Posted: Monday, March 05, 2012 - 01:37 AM UTC
The anti-slip material is described in Allied Torpedo Boats as either rubber or a 'Pyramid Rubber' I doubt it would have been painted as that would defeat the purpose, not to mention potentially degrade the rubber if the wrong type of paint is applied.
From all the drawings and pictures I've looked at I think they strips are present on all the Vosper boats. They might have been removed at some point but thats just a guess and given thier purpose it seems unlikely.
Connecticut, United States
KitMaker: 875 posts
Model Shipwrights: 872 posts
Posted: Monday, March 05, 2012 - 03:12 AM UTC
To Whomever is doing the Vosper...
NICE job.
Garth
KitMaker: 100 posts
Posted: Monday, March 05, 2012 - 05:05 AM UTC
Here is the photo on which i believe is no antislip aera.
Waiting to be proven wrong
TDK
KitMaker: 127 posts
Posted: Monday, March 05, 2012 - 08:00 AM UTC
I've got that image in a few books Tom, it does look like the anti-slip is missing, it might have something to do with fitting the Oerlikon, either when the deflection rail was added or maybe the coverings were getting damaged by muzzle-blast or staining possibly?
It's hard to tell for sure but I think you're right, there doesn't look to be any anti-slip on that boat and I can't make out the edging rail either.
Posted: Monday, March 05, 2012 - 10:17 PM UTC
Hi Tom and Les,
Thanks for the thoughts folks, sorry Tom it only occurred to me the other day when I was look at both builds. As the lines are there as you say you could still add a slightly different shade.
Thanks for the data folks.
Alan
'Action this Day'
Posted: Tuesday, March 06, 2012 - 01:13 AM UTC
Gentlemen, A question. In the kit, and in photos of MTB 77, there is a "Y" shaped item on the foredeck (parts 26E & 29E). I thought it was just a support for the antenna wires. However, in the photo below, all three boats have this thing right in front of the mast, on or next to, the bridge. Any ideas on what it might be?
http://i109.photobucket.com/albums/n44/11A_02/Als%20Boat%20%20Place/Vosper%20MTB/MTB234A.jpg :
It seems the more research you do, the more questions you have.
KitMaker: 100 posts
Posted: Tuesday, March 06, 2012 - 04:10 AM UTC
Afaik it's part of the radar or radio direction finder setup.
And when the oerlikon was placed on the fordeck it became a "target".
So they moved it to the bridge out of harms way.
TDK (Tom)
