...and on with the story
Next in line were the brake waters forward.
Another part that I was a little afraid of, but the Eduard etch is really good to handle!
Mr. Surfacer sufficiently cured, time for sanding
and painting and test-fitting.
I do like the crest on the bridge!
The next platforms up:
Ok, the point of no return: Structure glued in place, starting to fit ladders.
Well, if you have three long ladders to fit, it is the obvious decision to start with the only ladder that obstructs you from fitting the shorter one, visible pretty much centre of the picture, that you forgot in the first place. But that was still early on and I was able to fix it without any further damage. The small ladder is not perfectly in place, but that's almost invisible, even if you know what to look for.
There should have been one more ladder, leading from the first elevated platform into the chartroom (the extension of the compass platform), this one I forgot entirely. Should have been installed before fitting the structure in place. Anyway, it's invisible, and I could still claim it is inside my scratch build extension.
More ladders on the port side.
One more platform up -
- probably that would have been the perfect time to call it a day, but well...
Now it's certainly enough pictures posted for one day
thanks for looking and if you're still not fed up
the rest of the story will follow soon
I try tomorrow
but make no promises
For now
