Gentlemen!
Thank you so much for all your kind comments, encouragement and support
right now and throughout the entire build as well
And again I apologize for being sloppy on commenting all of your great builds over the last couple of days, some real great progress and even commission of HMS Achilles, cheers for that
however, as you are probably guessing, I had a job to do, and that's finally finished - so welcome to my final update to this build log!!
But there was some work to be done first -
lets start with the boats and the davids and nets.
And installed, together with the 'folded' accommodation ladder. Simply could not resist, they have REPULSE etched in their final step, not sure if you can see it on the pic.
Of course there are still touch ups needed, and you can see a little different colors from later spraying, that will all disappear soon
On with the final parts of the railing.
And now - what is left?? Some small parts that for one reason or another are not needed - may come handy in the future...
and a lot more parts that are waiting to be installed, mainly the smaller weapons and the two aircraft.
The aircraft still need some decals (not my favorite job, working with decals...tend to fumble them...)
Installing of the small stuff starts...
...and as so often, even simple installation of the weapons bears its dangers
This one went into a somewhat hidden position, touch ups still needed...
Half way...
...and getting there. I was tempted to leave the bigger ones (pompoms and triples) turnable but in the end decided to glue them all in place.
All right, I call this one finished
after only just over two years...
I started on 1 Feb 2013, but since then I had to move twice, had some period of quite intense work and a period of easily two month after my last move in June 14 where I almost could not fine any motivation to continue. So under normal circumstances I would estimate a year of building with my personal pace. So that should allow me to participate in the cruises campaign
I did not do any weathering this time, I am not much of an artist, so my weathering skills are not quite there yet, have to do some training. And I figured my REPULSE might not be the perfect object for experimenting
so I applied a coat of glossy clear to blend in all the painting done over the last to years and to provide some protection and finally a dull coat, a little bit as a filter. That stands out on some pictures due to too hard and direct light but is fine to the naked eye.
I make a break here in order to not to lose this and start a new entry with my finishing pictures.
