Thank you Si!
No, barrels don't go all the way through. The breeches are resin all right. Lots of fiddly parts... I am in the process of bringing up a bunch of pictures on the Belfast blog.
Official: Cruiser Campaign
Posted: Monday, January 11, 2016 - 01:37 AM UTC
Posted: Monday, January 11, 2016 - 03:10 AM UTC
Thanks Jan,
I hope that does not show on the finished article.
Posted: Monday, January 11, 2016 - 10:03 AM UTC
Thanks Jan,
Good point Si - never thought about that.
Well, I just checked. Show- no, in neither case (light or dark grey one). But, with a good light and my magnifier glasses on, knowing what to look for, yes - you can spot ist.
The dark one is a little easier to spot - the gold brass from inside the 'breech block' (how would you call it actually?) shines through. Good point, I will paint the inside before I bend it next time... Having those barrels go all the way through would have been a nice feature though...
Posted: Monday, January 11, 2016 - 02:26 PM UTC
Jan and Si,
Great work on your guns. If your cruising for a fight always best to be well armed
Posted: Tuesday, January 12, 2016 - 12:28 AM UTC
Thanks Michael,
I pleased they are now on.
Interesting Jan, still shouldn't be too difficult to cure with some plastic or brass tube.
Reckon I am going to try and get my hands on some of those.
Cheers.
Cheers.
Posted: Wednesday, January 13, 2016 - 07:14 AM UTC
Si, Great work on the armament. Your Scharnhorst looks like he is ready to put some steel on target.
Jan, Thank you for bringing that company to our attention. From the sounds of it they are good quality AM kits.
Posted: Thursday, January 14, 2016 - 01:05 AM UTC
Thanks Dave,
She is starting to come to life now she has tooled up.
Cheers.
Cheers.
MikeyBugs95
KitMaker: 2,210 posts
Model Shipwrights: 83 posts
Posted: Thursday, January 14, 2016 - 01:09 PM UTC
WOW! Great work here! I wish I saw this earlier I would've enlisted right away when I just started my 1/700 "sorta-super" detailed Cleveland build. If I can I'd like to enlist with that. It's probably 25-40% finished in the building stage.
Posted: Thursday, January 14, 2016 - 01:27 PM UTC
Hi Michael,
That is fine, the rules of this campaign allow started builds.
You would be very welcome.
MikeyBugs95
Posted: Thursday, January 14, 2016 - 02:13 PM UTC
Thank you. I guess I'll pretty much just copy/paste my first post of the blog with additions here and the latest update:
I will be "sorta-super" detailing the Midship Models 1/700 USS Miami. I read somewhere that you "can't really consider a build" super detailed" without a wood deck and, well, I don't have one.
But I also don't really consider this a superdetailing build either way. In terms of markings and painting, I plan on building the kit as the USS Miami CL-89 as she appeared in 1945 in Measure 22 Graded.
I will be using the Gold Medal Models USN Cruisers and Destroyers set, Tom's Modelworks Inclined Ladders, White Ensign Models Doors and Hatches and some sets from 3D Model Parts, specifically the 40mm quad and dual Bofors mounts, 20mm Oerlikons, the 5in/38 turrets and Mk37 and Mk51 directors. I have a set of Verlinden figures as well but I'm not sure if I will use them. I also had to buy another set of doors and hatches (meant for Japanese ships) because I almost ran out of usable doors from the USN set. Now onto the work so far...
Addendum: Since the original post I have also added Lionroar's Radar Set, Boat Davits and Anchors and Cable Holes set along with FStar's USN Doors and hatches. I also have a few pieces from an Alliance Modelworks Woban class tug that I'm using here. I might be forgetting a set... I will soon be adding even more to this. Below is snippets of the original post with updated details.
I'll let the pictures speak for themselves but here's the captionated version. I've replaced, and in some places added doors, hatches and ladders. I've also added ladders to 2 of the turrets where necessary (front for the 1 and 2 turrets and starboard side for the #2 as per some pictures) and I also cut and placed those circular extrusions on the turret sides. I plan on eventually adding some 40mm and 20mm ammo bins as well if I can find the correct placement. The 7th picture is a hawsepipe I made from a piece of sprue. I've since made a second with dental acrylic resin. I've now also made a 3D drawing an uploaded it to Shapeways. I've made cable holes on the bow from thin wire rolled around a medium-small sized drill bit and then using that bit, I drilled out the holes. I drilled out the hawsepipes holes and scraped off the molded on anchor chain. One catapult has been built along with the crane from the GMM set. The kit attachment point for the kit crane has been removed and sanded flat. On pictures of the ships I noticed a ring around the barbette for the #2 and 3 turrets. This I added along with a ladder extending from the ring to the base of the turret. I've just recently replaced asl the molded on "chocks," which were just little bumps, with the Lionroar chocks. I made the bow flagpole out of wire. Done early on was the drilling out of all visible (that I can find I mean) portholes. I tried thinning down some of the splinter shields but I haven't had much luck in doing so. I will leave them be for now. I've detailed the kit Kingfisher a little by adding wires for the struts. I also attached one funnel grill cap. A few of the 3D Model Parts parts have been assembled. But only 2 or 3. I've also cleaned up some holes and filled some dents and other small deformities. Still a long way to go.
More recent pictures with hawsepipes, kingfisher and flag pole/forecastle:
Note: none of these pictures represent the current state of the kit. The most up-to-date is the last one. But since then I drilled out the hawsepipes, removed the flagpole for safe keeping and replaced those two hatches, among other changes.
Apologies for the long post. I guess I just had a lot of catching up.
But I also don't really consider this a superdetailing build either way. In terms of markings and painting, I plan on building the kit as the USS Miami CL-89 as she appeared in 1945 in Measure 22 Graded. I will be using the Gold Medal Models USN Cruisers and Destroyers set, Tom's Modelworks Inclined Ladders, White Ensign Models Doors and Hatches and some sets from 3D Model Parts, specifically the 40mm quad and dual Bofors mounts, 20mm Oerlikons, the 5in/38 turrets and Mk37 and Mk51 directors. I have a set of Verlinden figures as well but I'm not sure if I will use them. I also had to buy another set of doors and hatches (meant for Japanese ships) because I almost ran out of usable doors from the USN set. Now onto the work so far...
Posted: Thursday, January 14, 2016 - 02:29 PM UTC
No worries Mike,
Great looking build, very nice etch work, welcome aboard.
Could you pls nip over the Campaigns tab at the top of the page and enlist, (select the cruiser campaign, and click on the enlist button).
many thanks
many thanks
MikeyBugs95
Posted: Friday, January 15, 2016 - 01:46 AM UTC
Yep. I enlisted. I also got one of the supports for the boat davits up.
Posted: Friday, January 15, 2016 - 03:53 AM UTC
Excellent Michael,
Properly welcome aboard.
Cadeus
KitMaker: 144 posts
Model Shipwrights: 139 posts
Posted: Friday, January 15, 2016 - 06:39 AM UTC
Well here goes nothing. The 1/350 Academy USS Indianapolis (deluxe edition). This kit was started awhile ago and has made its way back to the bench. While im not in the realm of some of these builds i hope to do her justice. Has been a fun build so far albeit has tested my patience at times. Now on to official business.
Cadeus
KitMaker: 144 posts
Posted: Friday, January 15, 2016 - 06:40 AM UTC
Cadeus
KitMaker: 144 posts
Posted: Friday, January 15, 2016 - 06:49 AM UTC
There are a bunch more build photos to my facebook and anyone that wants to see can add me to there. Its a pain to add photos from my phone because at the moment its all i have. Thanks for allowing me to join this campaign.
GrantGoodale
KitMaker: 99 posts
Model Shipwrights: 99 posts
Posted: Friday, January 15, 2016 - 07:23 AM UTC
Nice work. Thanks for sharing
GrantGoodale
KitMaker: 99 posts
Posted: Friday, January 15, 2016 - 07:24 AM UTC
Very nice photo-etch work. I am envious.
Cadeus
KitMaker: 144 posts
Posted: Friday, January 15, 2016 - 07:29 AM UTC
My phone hides the imperfections. Thanks for the kind comments. Im still learning.
Posted: Friday, January 15, 2016 - 02:15 PM UTC
Hi Norman,
Looks like a very start to the Miami. Interestingly, those main turrets look like they should house much bigger guns than 6".
MikeyBugs95
Posted: Friday, January 15, 2016 - 09:15 PM UTC
Hi Norman,
Norman's doing an Indianapolis. I'm doing the Miami. Lol
Cadeus
KitMaker: 144 posts
Posted: Friday, January 15, 2016 - 09:22 PM UTC
Yes, im doing the CA-35. I live 15 minutes from indianapolis so its a special build to me. The indy had 8" guns on her. And i highly recommend this build to anyone. The fit is impressive.
Posted: Friday, January 15, 2016 - 10:50 PM UTC
Hi Norman,
Very nice work on the Indy, looking very good indeed.
Will be looking forward to seeing her come on.
Cheers.
Cheers.
Posted: Sunday, January 17, 2016 - 07:39 AM UTC
Quoted TextHi Norman,
Norman's doing an Indianapolis. I'm doing the Miami. Lol![]()
Apologies to you both. I obviously completely lost the thread there
Cadeus
KitMaker: 144 posts
Posted: Wednesday, January 20, 2016 - 07:00 AM UTC
Small update here. Mostly painting is going on. The deck blue takes multiple coats. Indecided to go the hairy stick route and with how thin the enamel paint is im regretting it. Also mocked up the bridge assembly to see how to tackle it. And this is one amazing fitting puzzle. The fit is great but the parts are tricky. On to the two pictures i have this evening. Waiting on paint to dry.
