Posted: Wednesday, December 11, 2019 - 07:13 PM UTC
Love the small boats, Si! She's really coming along nicely!
Posted: Thursday, December 12, 2019 - 08:26 PM UTC
just catching up really quick - awesome work, she looks splendid!! Looking forward to see her approaching the finish-line!
Posted: Friday, December 13, 2019 - 07:44 AM UTC
Again nice progress. How did you mount the railings? Are there holes for the posts? At 350 scale I have a dickens of a time getting those posts to attach because of the tiny surface area. It becomes a real pain to mark and drill holes.
Mark![]()
Hi Mark,
They have small feet which are bent up to give ta bit more area to stick down.
How these will be replaced with the kit railings, as they are not long enough to go round the shielded 3" guns on the gangway ends. (When I can find that particular fret, which I have put in a very safe place, that safe I cannot remember whre it is
)Cheers
Posted: Friday, December 13, 2019 - 08:31 AM UTC
The details look really effective Si, especially those boats.
Thanks Ned,
The larger scale does help.
Appreciate you looking in.
Posted: Friday, December 13, 2019 - 08:41 AM UTC
Thanks Gaz,
The scale really allows the detail to come out.
Posted: Friday, December 13, 2019 - 08:42 AM UTC
Thanks Jan,
Quite a way to go yet, bridges, masts and all sorts of other bits and pieces.
Appreciate your support along the voyage.
surfsup
Posted: Saturday, December 14, 2019 - 03:59 PM UTC
The Boats are looking great Si. Lovely work so far.....Cheers mark
Posted: Saturday, December 14, 2019 - 10:38 PM UTC
Thanks Mark,
The quality of the kit and the aftermarket help. Still quite a way to go, and some of that will be dealing with the big differences between the 1902 & 1905 fits, which will involve adapting some of the Pontos parts.
Posted: Friday, December 27, 2019 - 10:05 AM UTC
Finally found the missing fret with the railings for the Gangway, so onwards & upwards.
The fret sprayed, well at least the two parts I need.
Fitted in place.
Basic assembly of one of the Pontos " guns, next to the Kit etched gun shield.
Test fitting the gun shields, Pontos & kit 3" gun.
Unfortunately the Pontos parts don't work well with the kit shields, a major rework would be needed. I did try fitting a Pontos barrel to a kit gun; that went well... not. Decided to go with the kit parts.
The kit parts have had some added detail from some Pontos bits.
The shielded 3" guns fitted on one Gangway.
One Pontos 47mm built, kit shield beside it.
Test fitting.
No glue, so it is a bit droopy, but it will work.
More soon.
Fitted in place.
Test fitting.
More soon.
Posted: Friday, December 27, 2019 - 10:12 AM UTC
Those Pontos guns look really nice, to bad you couldn't use them. Things are really shaping up nicely.
Posted: Friday, December 27, 2019 - 10:18 AM UTC
Those Pontos guns look really nice, to bad you could use them. Things are really shaping up nicely.
Mark![]()
It is a pity Mark, well for the 3", but as they are sitting behind shields, no too much of a disaster. At least I will be able to use the 47mm.
Thanks fro looking in Mate.
Posted: Friday, December 27, 2019 - 03:45 PM UTC
She's looking beautiful. Do you always paint the rails before adding them?
Gaz
Gaz
Posted: Friday, December 27, 2019 - 10:32 PM UTC
Gaz
Hi Gaz,
It really depends if I can add the railing prior to painting I do, take a look at my HMS Eskimo 1940 build, the railings are going first there. On this one they have to fit around etched deck sections, or wood deck, so they go on much later and then I pre-paint them, I just have to careful with the glue.
Thanks for looking in mate.
Posted: Monday, December 30, 2019 - 06:09 PM UTC
Secondary armament looking good Si
Posted: Monday, December 30, 2019 - 11:14 PM UTC
Secondary armament looking good Si![]()
Thanks Russ,
More of that coming.
Posted: Tuesday, December 31, 2019 - 12:16 AM UTC
A bit more armament.
The pontos 47mm.
Shown is an assembled barrel unit, along with the single piece of etched origami that forms the breach.
The four units that sit on the gangway and their shields assembled and sprayed.
Detail painted and assembled.
Fitted to the Gangways.
The four boats that sit on the Gangway.
painted.
The detail on the steam launch is a little basic & shallow, but paints up ok.
Gangway boats in place.
On with the upper bridges next.
The pontos 47mm.
painted.
Posted: Tuesday, December 31, 2019 - 12:50 AM UTC
She is shaping up really nicely with the addition of those 47mm and launches.
Posted: Tuesday, December 31, 2019 - 04:48 AM UTC
Mark![]()
Thanks Mark,
She is getting there, bridges next, then the big guns.
Happy New year.
Posted: Tuesday, December 31, 2019 - 09:47 AM UTC
She's looking mighty smart amidships, Si!
Choowy
KitMaker: 125 posts
Model Shipwrights: 125 posts
Posted: Tuesday, December 31, 2019 - 10:22 AM UTC
Those boats look amazing Si, nice detailing, just keeps getting better with each layer.
Posted: Tuesday, December 31, 2019 - 09:38 PM UTC
Thanks Ned,
I do like the depth of detail you get in the larger scales.
Happy New Year
Posted: Wednesday, January 01, 2020 - 10:14 PM UTC
Moving along nicely Si... nice to see the black, white and red on this one
Posted: Thursday, January 02, 2020 - 07:43 AM UTC
Moving along nicely Si... nice to see the black, white and red on this one![]()
Thanks Russ,
One think I haven't come to a conclusion on yet as to the colour of the masts, the box art and the colour plan shows the to be a yellow / buff (which I will admit is tempting, and would fit in with the IJN's British links of the period) but I have also heard and seen light grey or white.
Posted: Monday, January 06, 2020 - 09:41 AM UTC
This weekend's progress.
Started work on the fore bridge.
First the destruction.
The kit parts as moulded.
detail removed.
The gouges will be covered with a wood deck.
The underside and the etch to cover it.
I have started to fold the structure.
Structure going on the underside.
done, ready to receive for the framework that supports it.
More soon.
detail removed.
More soon.
Posted: Monday, January 06, 2020 - 10:07 AM UTC
SI,
Your PE work always looks great.
Those gouges look deep, sure the decking will sit OK without a good backing?
