LHD-1 USS Wasp build
tribun
KitMaker: 164 posts
Model Shipwrights: 119 posts
Posted: Monday, January 23, 2012 - 03:35 AM UTC
Charles, the slat came as PE frets, one piece each the slat on the rear door, one the right side and one the left side including the front part. Joins to the hull had to be bent and glued with super glue. Quite a fiddling
.RedDuster
Posted: Wednesday, January 25, 2012 - 09:45 PM UTC
Hi Julian
The Airwing is looking good, like all the little touches of colour, like the forklift.
Great work
Great work
Posted: Thursday, January 26, 2012 - 03:42 AM UTC
Thank you very much Simon, it looks a bit better now doesn't it? I'll be adding some crewmen this weekend. Also getting the wiring to get the Leds going, (I hope
). I have also added an extra set of deck vehicles so there will be a couple more tow tractors and a forklift added before closing everything up.
Julian
). I have also added an extra set of deck vehicles so there will be a couple more tow tractors and a forklift added before closing everything up.Cheers,
Julian
Posted: Friday, January 27, 2012 - 03:29 AM UTC
January 27th update:
Micro crewmen and a tow tractor fitted. That's about all the progress that has been made this week:
Next some wiring and bringing things together.
Julian
Julian
tribun
KitMaker: 164 posts
Posted: Friday, January 27, 2012 - 03:37 AM UTC
Astonishing, I must say, Julian. Really looking good, I especially like the CH-46 or "Phrog". Did you use KA PE rotors with it? How did you cope with the single rotor blades?
Posted: Friday, January 27, 2012 - 03:45 AM UTC
Hi Daniel, yes, KA PE rotors on the "Not a Chinook"
No problem at all Daniel, Bent a gentle curve into the blades before glueing them to the hubs. The hangar looks busy enough to me now so Its time to get things fitted into the hull, (hopefully with some illumination).
Julian
No problem at all Daniel, Bent a gentle curve into the blades before glueing them to the hubs. The hangar looks busy enough to me now so Its time to get things fitted into the hull, (hopefully with some illumination).Cheers,
Julian
johndon
KitMaker: 120 posts
Model Shipwrights: 34 posts
Posted: Saturday, January 28, 2012 - 06:46 AM UTC
Looking very nice indeed Julian.
John
John
Posted: Saturday, January 28, 2012 - 06:59 PM UTC
Thanks John !
Julian
Julian
warreni
KitMaker: 5,926 posts
Posted: Saturday, January 28, 2012 - 07:41 PM UTC
Looking good Julian.
Have you found out the name of the "Not A Chinook" yet? I made one in 1/72 scale about 3 decades ago. Airfix back then as that was about all that was available..
How times have changed.
Posted: Saturday, January 28, 2012 - 08:13 PM UTC
Certainly did, it will remain a "not a chinook " for the rest of this build though
I rather Daniels name for the little bug as well
Julian
Julian
Posted: Sunday, January 29, 2012 - 04:33 AM UTC
My planning has gone slightly pear shaped. I had planned to get soldering this weekend but I realised in time I would runto some problems if I install everything inside now. At the moment I am working on the outer hull before installing everything.
A small warning to all the other LHD builders in the forum: the decals for the Lcu's are horribly off register so I would suggest a quick check.
Julian
Julian
trahe
KitMaker: 1,158 posts
Model Shipwrights: 117 posts
Posted: Monday, January 30, 2012 - 12:41 AM UTC
Julian, the build is looking great! How are you running the wiring for the LEDs? Are they battery powered or do you have a transformer?
Posted: Monday, January 30, 2012 - 05:59 AM UTC
Hi Thomas, through the lower hull and then around the vehicle bay and well deck, up to the hangar bay and from there back down to the lower hull and out through the stand. Idea is to solder the led's in series. Power supply by a transformer. That is why I had to do some work on the hull first. Just hope it all works
Julian
Julian
trahe
Posted: Monday, January 30, 2012 - 06:46 AM UTC
Cool. I may copy your idea for LEDs when I finally get around to building my Wasp. I am working on a Nimitz class carrier right now and am using luminous film for lighting the hangar bay.
Posted: Monday, January 30, 2012 - 08:28 AM UTC
Sounds good Thomas, how about some photos?
Julian
Julian
Posted: Monday, January 30, 2012 - 08:30 AM UTC
Small update:
While waiting for the hull to dry I had a go at one of the LCU's:
Nearly finished this little ship. some odds and ends and of course it's load.
Julian
Julian
Posted: Monday, January 30, 2012 - 09:40 PM UTC
Hi Julian,
Hanger bay looks good, the figures and vehicles add a real touch of depth and life.
The LCU has a nice level of detail, looks like a kit in it's own right.
great job
great job
Posted: Tuesday, January 31, 2012 - 12:12 AM UTC
Thanks Simon,
the Lcu was a fun build. Only takes a couple of hours too.
Cheers.
Julian
Cheers.
Julian
tribun
KitMaker: 164 posts
Posted: Tuesday, January 31, 2012 - 06:52 PM UTC
Keep up the good work, Julian. Little LCU looking great!
Posted: Wednesday, February 01, 2012 - 08:15 AM UTC
Hi Daniel, thanks
Julian
Julian
Posted: Sunday, February 05, 2012 - 02:14 AM UTC
February 5th update:
after replanning the build I have been fitting all the catwalks, platforms etc. on the hull sides. The Wasp is looking a bit like a dog's dinner at the moment. I sprayed the catwalks this after noon, (temperature is up to 0 centigrade at the moment after a stunning -18 centigrade yesterday morning. Also fitted the MOB boat, so after some masking I can spray the haze grey hull sides and fit the innards at long last:
Julian
Julian
tribun
KitMaker: 164 posts
Posted: Monday, February 06, 2012 - 11:25 PM UTC
Good work, Julian. Nice to see those detailed PE parts coming together!
DanielMoscatelli
KitMaker: 998 posts
Model Shipwrights: 941 posts
Posted: Tuesday, February 07, 2012 - 12:59 AM UTC
Hello Julian!! Very good work and the LCU simply brilliant!!!
Posted: Tuesday, February 07, 2012 - 04:32 AM UTC
Good work, Julian. Nice to see those detailed PE parts coming together!![]()
Thanks Daniel,
It really needs a coat of Haze Grey at the moment
Watch out when you get to fitting the MOB boat, the PE straps supplied were either too short or I fitted them wrong
Had to remove them and replace them with thin evergreen strip. Hope the temperayure goes up a bit so I can do some spraying on the Wasp
Julian
Posted: Tuesday, February 07, 2012 - 04:34 AM UTC
Hi there Daniel, thank you sir ! I would love to see what you with your great talent could make of this model. The LCU and LCAC are small models in their own right. It is a fantastic model and the first one evr I would consider building a second time to get everything right
Julian
Julian
