Channel Adversaries
Posted: Thursday, October 31, 2013 - 06:24 AM UTC
Probably watching the nieghbours bedroom window............
DanielMoscatelli
Montevideo, Uruguay
KitMaker: 998 posts
Model Shipwrights: 941 posts
Posted: Friday, November 01, 2013 - 02:42 AM UTC
ssssssshhhhhhhh !!!!
Daniel .........
DanielMoscatelli
Montevideo, Uruguay
KitMaker: 998 posts
Posted: Friday, November 01, 2013 - 02:50 AM UTC
It told me a little bird ... that the opposite decree, to seeing Schnellboot's quantity with keel put in shipyard ... an requested help to his allies.....
Daniel .....
Posted: Friday, November 01, 2013 - 03:51 AM UTC
No Daniel, this is the entire Dutch navy after all the budget cuts that our Premier Rutte has foisted on Holland so he can give more money to the EU.
warreni
South Australia, Australia
KitMaker: 5,926 posts
Posted: Friday, November 01, 2013 - 06:53 AM UTC
The Advanced Griffon set is on special at Luckymodel...
Posted: Friday, November 01, 2013 - 07:02 AM UTC
That is a "must have" as far as I am concerned warren. Luv'ly Jub'ly as our speech impeded Jamie Oliver says
Longshanks8
KitMaker: 430 posts
Model Shipwrights: 390 posts
Posted: Friday, November 01, 2013 - 08:16 PM UTC
Get thee behind me satan(s) !!
Just about to order it and saw its on back order
Next weekend is IPMS Telford, going to see what I can pick up there...
Cheers Kev
Posted: Friday, November 01, 2013 - 09:19 PM UTC
Cheers Kev
and how about the Italeri add-on set so that you have a 20mm Oerlikon, and...................there are several advertisments circulating for the Italeri RN crewmen so it looks like that set will be released soon and...............
warreni
Posted: Friday, November 01, 2013 - 09:28 PM UTC
Hello Warren, she looks terrific. Have you tried applying the decal for the flag to a piece of aluminum foil? I spray a primer onto one side of a piece of foil, apply the decal, trim it, and then apply CA glue and depending on the flag, glue it to, or wrap it 'round, the halyard. You will probably have to touch up around the edge of the flag. The foil allows you to shape the flag realistically.
I'm looking forward to seeing some more photos. Al
I took your excellent idea Al and modified it a bit by putting said white ensign on Bare metal foil, the self adhesive stuff. Took out the need for glue and it is a bit thinner than aluminium foil.
Warren
TAFFY3
KitMaker: 2,531 posts
Posted: Friday, November 01, 2013 - 09:44 PM UTC
Warren, Good idea about using the Bare Metal foil, never thought of that. Al
DanielMoscatelli
Montevideo, Uruguay
KitMaker: 998 posts
Posted: Saturday, November 02, 2013 - 08:13 AM UTC
View 360º
continuara .....
DanielMoscatelli
Montevideo, Uruguay
KitMaker: 998 posts
Posted: Saturday, November 02, 2013 - 08:19 AM UTC
Aghtug!!! The generators 24 volts estan working!!! Only it is necessary to repair the generators of smoke!!!!
Pardon for the quality but they are of the mobile
Posted: Saturday, November 02, 2013 - 08:43 AM UTC
Beautiful Daniel, the chipping of the twin 20 is excellent and the led lighting for the navigation lights looks fantastic. I am pleased to see you chose Hans Jürgen's ship as the subject of your build I will get some photos up tomorrow. I am getting an amazing amout of PE to behave in a very small area on the vosper I am trying to get clear-view screens fitted on an acetate window without leaving glue marks. This is really freaking me out, (not to mention knocking a hole in my supply of medicinal brandy ).
P.s. if you are going to smoke Cuban cigars to get your smoke generator going use only Romeo y Julieta Cigars. I have fond memories of a fantastic holiday in Havana drinking Havana club rum, (without any other ingredients), and smoking Romeo Y Julieta's with an elderly Cuban gentleman who had fought alonside Castro and Ché. One of the more memorable evenings in my entire life.
TAFFY3
Posted: Saturday, November 02, 2013 - 12:54 PM UTC
Beautiful work Daniel, the guns and the lights look terrific. I dove into the deep end of the pool today. I had ordered some of Bob Palmacci's plans, including the one to correct the bow gun tub. This is the end result.
I'll admit it was pretty scary cutting up a major part of a rather expensive kit. I bought a metric circle drafting template, and used that to make a template of my own, visible at the bottom of the photo. I made it to fit between the two rails on top of the foredeck. Then taped it into place and used a home-made scribing tool to cut out the larger opening in the deck. The plastic was very thick and it took quite a lot of work but it was worth it in the end. Now I think I'll have a nightcap, or two, to celebrate, and to ease my nerves. Al
Longshanks8
KitMaker: 430 posts
Posted: Saturday, November 02, 2013 - 07:35 PM UTC
Courageous work Al
Another Schnellboot on the horizon We definitely need a Fairmile D to even things up in the channel !!
Cheers Kev
Posted: Saturday, November 02, 2013 - 11:31 PM UTC
November 3rd update:
I managed to get the clearview screens in without messing up the windows, one of the blessings of Gator Grip
The flying bridge side are very nearly ready for grounding and painting, the windows have been masked with Vallejo masking fluid.
TAFFY3
Posted: Sunday, November 03, 2013 - 02:46 AM UTC
All that brass certainly dresses up the bridge quite nicely. Al
Posted: Sunday, November 03, 2013 - 02:54 AM UTC
It is basically what is already supplied in the box. The brass is just so much sharper though. I think with some paint it pulls together. Should look good.
Thanks Al,
DanielMoscatelli
Montevideo, Uruguay
KitMaker: 998 posts
Posted: Sunday, November 03, 2013 - 03:58 AM UTC
Great work with all this PE!!! Give pity to have to paint it!! Julian that they are these ropes or wires?? Are they to hold to do??
Well Al , I see that these on fire!! Jejjeje very god!!!
Kev .... I believe that you needed a Destroyers' couple.....
Regards ......and I finish the torpedoes ......soon
Posted: Sunday, November 03, 2013 - 04:15 AM UTC
I think they need replacing because they are much too thick. Supposed to be lines to roll up the covers of the flag boxes. They look more like tow lines
DanielMoscatelli
Montevideo, Uruguay
KitMaker: 998 posts
Posted: Sunday, November 03, 2013 - 09:37 AM UTC
Julian ..... and you who thinks??
Daniel
Posted: Sunday, November 03, 2013 - 12:22 PM UTC
Again very nice work indeed Daniel!
Posted: Sunday, November 03, 2013 - 05:11 PM UTC
The resin production line ! excellent Daniel,
DanielMoscatelli
Montevideo, Uruguay
KitMaker: 998 posts
Posted: Thursday, November 07, 2013 - 02:43 AM UTC
Hello friends ... thank you for the comments!! Yes the resin takes a lot of work!!!! I continue learning.
I present my Flak 37 mm....
Continuara ....
TAFFY3
Posted: Thursday, November 07, 2013 - 04:43 AM UTC
Beautiful! Al
