Thanks Jan,
Going to do a bit of work inside the spotting top first.
No pics of the inside but have the AOTS on HMS Hood to give some inspiration and ideas.
HMS Repulse May 1941
Posted: Friday, June 10, 2016 - 12:38 PM UTC
Posted: Saturday, June 11, 2016 - 03:03 AM UTC
Posted: Saturday, June 11, 2016 - 11:36 PM UTC
One this missing, according to photos, and the GMM set is a yard arm on the mainmast.
made up and fitted.
The Admiralty boats and the Raven & Roberts dwawing. Trying to work out what goes where.
The 35 ft fast motor boat that does in the middle of the boat deck.
The chocks from the WEM set are designed for the kit boats. so are not brilliant on the more accurate AM boats, but the will work.
Finally for today the director on the spotting to painted and in place.
made up and fitted.
Posted: Sunday, June 12, 2016 - 12:16 AM UTC
Once more this Admiralty kit seems a really fine piece!! The boats look really good!
Nice progress once more, Si
She's getting there!
She's getting there!Cheers,
Posted: Sunday, June 12, 2016 - 12:45 AM UTC
Posted: Monday, June 13, 2016 - 02:31 AM UTC
Magnificent progress, my friend!
Repulse is nearly looking ready for commissioning!
Posted: Monday, June 13, 2016 - 11:59 AM UTC
Thanks Russ,
Yup, only the boats, rigging, armament, maindeck railings and a few other bits and pieces to go.
Posted: Saturday, June 18, 2016 - 12:16 AM UTC
Boats today (probably tomorrow as well)
The boats that sit on the engine room vent housings. 45ft fast motor bot on the port side, and a stack of open boats on he starboard.
The AM castings.
sprayed.
The fast motor boat and the motor cutter sat on the vents.
You were right Jan, I did initially have them the wron way round; good spot mate.
The AM castings.
sprayed.
Posted: Sunday, June 19, 2016 - 10:52 AM UTC
Boats look great, anyway!!
They'll really stand out once in place! This is going to be one outstanding Repulse, Mate!!
Looking forward to see her approaching commissioning!Cheers,
Posted: Monday, June 20, 2016 - 12:55 AM UTC
Thanks Jan,
High praise indeed, I will do my best not to disappoint.
A bit more progress on the boats yesterday, will post a bit later.
Posted: Monday, June 20, 2016 - 01:54 AM UTC
Small progress yesterday, a bit of time spent working out how the outer 45ft motor boats fit.
On issue is they have a Carley floats sat under them, so the fit of the cradles needs to be precise.
The Carley Floats in place.
Working out the fit of the motor boats. It appears the moulded in cradles were not quite in the right place.
The WEM chocks are meant for the kit boats so needed adapting for the AW boats, and raising to fit over the floats.
More boat fun next update.
surfsup
Posted: Tuesday, June 21, 2016 - 05:07 AM UTC
Very nice work so far Si.....Cheers Mark
Posted: Wednesday, June 22, 2016 - 11:41 PM UTC
Thanks Mark,
She is getting there, still quite a way to go.
TRM5150
Posted: Thursday, June 23, 2016 - 04:00 AM UTC
Tidy fitting of the rack Si!! Very clean work as usual! Back to the detail painting with the boats is seems! Enjoy!
Posted: Thursday, June 23, 2016 - 09:55 PM UTC
Thanks Todd,
You are dead right there mate. Hope to get into the workshop tomorrow and crack on .
Posted: Saturday, June 25, 2016 - 12:40 AM UTC
Cracked on with the boats.
two 45ft motor boats, and the all the other boats I hadn't got round to sprayed.
The boats for the starboard vent, all painted and ready to be stacked.
Stacked,
The 45ft motor boats painted, just need their lashings and they will be ready to go.
The main big boats test fitted in place.
Might get a little further tomorrow.
Stacked,
surfsup
Posted: Saturday, June 25, 2016 - 11:51 AM UTC
The Boats are looking very good Si.....Cheers mark
Posted: Saturday, June 25, 2016 - 01:25 PM UTC
Thanks Mark,
The AM boats are superbly cast, and bags of detail that does help.
Posted: Sunday, June 26, 2016 - 02:56 AM UTC
Before I fix the boats down, I thought it might be a good idea to make sure they don't foul each other.
I am using the WEM cranes with the GMM rigging, as they look closest to the drawings in Raven & Robberts.
The "cab"
The origami of the jib, about half way there.
The plastic rod and strip added as per the WEM instruction, and the origami done.
rigging fitted to the cab.
One crane done!
The "cab"
One crane done!
Posted: Saturday, July 02, 2016 - 01:33 AM UTC
Posted: Saturday, July 02, 2016 - 11:19 PM UTC
Once more, very nice work, Si!!
The color effects on the carleys and the boats really stand out, gives a much more vivd impression than the overall grey! I like that very much!
Posted: Monday, July 04, 2016 - 01:20 AM UTC
Thanks Jan,
I am pleased with the way they have come out, and the Admiralty boats have a ton of detail to bring out, the Kit carleys are very good as is, and look better than better than the two hidden down on the superstructure that I replaced the bottoms with etched mesh.
The other trick is Citadel washes, or "Shades" as they call them, very easy to use and a small pot goes a long way.
Posted: Monday, July 04, 2016 - 02:23 AM UTC
Posted: Wednesday, July 13, 2016 - 09:36 AM UTC
Great work, Si!
The boat deck is really coming to life!!
Posted: Thursday, July 14, 2016 - 01:03 AM UTC
Thanks Jan,
The Admiralty boats are so well cast, that a gentle drybrush and a quick wash, and all the detail pops out.
