Tim, your attention to detail is always so impressive!
Surely this will take centre place in your "fleet"display when completed!Quoted TextOk, I’m going to go and bury all my models in the backyard now. Tim, how the heck do you drill holes that small? I’ve broken dozens, maybe hundreds of steel, tungsten and hardened brass drill bits in my sixty years of modeling. I’ve used pin vices, variable speed drills, even tiny drill presses, but I couldn’t get consistent holes like you’ve done. Show us your secret. Do you have a secret NASA titanium set of tiny drill bits and a sub miniature electric drill?
VR, Russ
Russ, I find when drilling holes, it pays to "spot" them prior to drilling them with some sort of sharp pointer, that way you get the location exactly where you want it when you position the drill...
Thanks Russ - that is exactly what I do. I start by making a small starter hole with the tip of a No. 11 X-acto blade. Then I simply hand twist out the holes with a No. 80 drill bit set into my X-acto knife handle. There are no special tricks or tools, just slow and methodical work.
By the way... I bought six of the fragile No. 80 bits for this project, and I'm now down to just two...
