Tom I'm expecting a museum piece out of you. I'll make an effort at matching you to a degree when I do my NC. I've ordered that Lions Roar set that had 17 sheets of brass and the brass main and 5" guns. YEEHAW some fun to be had with that.
Well it sure is taking up enough time!!! I'm still making steady but slow progress. All the solid bridge windows have been removed from both levels. When you do that you can now see inside a bit, so of course you have to fill in the armored conning tower around which the bridge was built. (Molded a piece using "Sculpy" clay.)
The GMM PE set has window frames and after I've painted, I'll put some clear acetate inside them and install them. It also appears that on the top level, there were clear plates of glass on the foreward face, which had covers that could be raised or lowered, so I'm doing that as well. Covers are now on in the lowered position, and after painting, I'll put in the "glass".
I've gotten rid of the molded ladders on the 01, 02 and 03 decks by grinding them off and will replace them with PE. Because of the way the kit was molded, grinding off the ladder also opened a hole in the bulkhead (that's a wall for you land lubbers), and of course that had to be filled in with sheet styrene. Luckily, there is also a hatch that goes right there so part of the "surgery" will be covered up.
There was one ladder that wasn't included in the kit, and that required cutting an opening in the deck to insert a PE ladder through to the lower level.
I finally got the L'Arsenal 25 man rafts (Thanks to John from WEM!!!) and have added all the rafts to the three main gun turrets. Those are SO much better than the kit supplied versions. My only gripe is that they only have 10 PE tie downs for 20 rafts. The instructions indicate that these should be used when you stack rafts, but the photos clearly show that the singles hung on the sides of the main guns are held down this way as well. Hope I don't run out!
And I'm getting close to finishing up the remaining L'Arsenal quad 40 mm mounts. Those are a bit tricky to build, but I've discovered that rather than build one complete one at a time, it's much easier to do the exact same step in the process for all the remaining mounts. If anyone has these and is going to use them (they are fantastic BTW), I've discovered a couple of tips that will help, so let me know.
Once I get them all done, I'll shift over to painting, as I also have the 4 Mk 37s which need that, and some touch up work on the hull. After I finish up that part of the painting, I PROMISE I'll get some more pictures.
Tom
