Trumpeter BB55 NC, with aftermarket.
I am way behind -- over two months to get 5 parts glued together isn't gonna cut it. While I've had other things going on, I've had some problems as discussed below.
First, I've added the Gold Medal PE set for the NC to my parts list - it may be the best of all. I also have L'Arsenal 20mm & 40mm ... You can see pix in my Gallery, Dreadnought album (DRN23-DRN26 series)...
The issue has been that the upper & lower hull did not match up. I cut the crossmembers in the upper hull & fitted until the hulls matched, then rejoined the cross-members. See picture below and a bunch more in My gallery, Dreadnought album (DRN40-DRN43 series). You'll also see quite a bit of putty to final the fix and cover some sink marks, etc.
However, my fix to the hulls caused other problems - it essentially drew in the upper hull sides and that meant the decks didn't fit into the hull easily. That wouldn't have been so bad if there =weren't problems with those parts to start -- especially to terrible fit on the deck of the three deck sections. See picture below & My Gallery (DRN45-DRN46 series)-- trying to clean up the two deck seams and rescribe the planking will be tough - and that is my next step.
I'd like to get past this point so I can get in gear with all the superstructure & stuff -- I mean, counting PE & what not, I've only got a couple thousand parts to go here. I am not a happy camper and that has caused me to walk away from this thing too many times. I am going to focus a bit more & try to get back on track. But if I don't get the deck seam cleaned up shortly, I'm going to put it all away & do something fun.
John
