Hi folks or shoudl I say JBA
I finally decided what I want to do with the 1st floor.
This has been quite difficult to figure out. But I'm leaning towards the following:
A small radio area with some filing cabinets, typewriter, telescope and civilian radio. There will be a No 19 Radio set and equipment on top of the table, with a couple of books. I need to replace the clock that got damaged in the plastering and put something else on the rounded tower wall.
By the stove I have only a couple of small wooden benches, some logs, a bucket of coal and there will be some household stuff, cups, a coffe pot, boiling pan etc. On the walls I plan to put a couple of small pics.
On the plain wall next to the radio section I will put a sea chart/map on the wall.
If I put in some hangers then a few helmets, and bits of personal equipment might give enough interest.
Having to plaster the walls buggered up my original wooden paint scheme and it's not quite back to what I want.
This is an odd shapped space to think about, but I hope you approve of the general idea.
I'll probably put a poster of some sort on the top of the door. I have looked at early office furniture and most of it is of wooden construction. However, I've tried this and it's just too much wood and as best I can find out metal filing cabinets have been around since the early 1900s if not before. The grey also helps give some contrast to the dark wood which is quite over powering.
This I hope will represent a temporary command and comntrol centre in an other wise civilian building. A couple of as yet unidentified figures will complete the scene and one or two stacked boxes. With the top section and windows in place I think this would do.
Shay thanks for the little radios, they are great.
Thoughts and suggestions welcome:
Radio Area
Stove area
These are some of the wonderful posters I'll be able to use on the project thanks to Paul.
I was thnkinng that they would be just pasted to the wall and a run of 3 roughy square with a couple below at off angles might work.
Pin ups on the filing cabinate and one of Shay's excellent early radios
A Poster for the door?
Other elements still pending:
Food for the lads - the Fordson Mobile Canteen
