Nordrhein-Westfalen, Germany
KitMaker: 673 posts
Model Shipwrights: 386 posts
Posted: Tuesday, March 19, 2013 - 09:52 AM UTC
Yes, 31 of the remaining XXIII's were scuttled in early May 1945 and 20 more surrendered to the allies and ended their careers in Operation Deadlight. Only U-2326 (later UK sub N 35), U-2353 (later the UK sub N 37) and U-4706 (later the Norwegian Knerten) survived the war.
http://www.uboat.net/types/xxiii.htm Here you can also find the history of all 61 commissioned U-boats of this type.
Btw, the most successful XXIII-boat was U-2336, 2 ships sunk (4,669 GRT) and 1 u-boat , U-2344 by ramming during an exercise!
KitMaker: 2,531 posts
Posted: Tuesday, March 19, 2013 - 10:51 AM UTC
Apparently N-35 was sunk in 1946, in Toulon harbor. The result of an unspecified accident. I couldn't find anything on N-37's service or fate. Al
KitMaker: 673 posts
Posted: Tuesday, March 19, 2013 - 03:57 PM UTC
U-2353 was later the UK sub N 37.
...and here (
http://www.uboat.net/boats/u2353.htm)we can find a scribal error:
Allocated to the USSR by the TNC. Arrived Libau (Latvia) on 4 Dec 45with RN Pennant No:
N.31 . Allocated to the Baltic Fleet on 13 Feb 46. Renamed M-51 on 9 Jun 49. To reserve as a training hulk on 22 Dec 50. Struck from Soviet Navy list on 17 Mar 52. Broken-up for scrap in 1963.
That's the story of
N37, for H31/N31 was a real british sub.
http://uboat.net/allies/warships/ship/3648.html
KitMaker: 14,499 posts
Posted: Tuesday, March 19, 2013 - 08:35 PM UTC
Hi Al and Michael,
Thanks for the info and links guys, thought it might be an interesting option.
'Action this Day'
Winston Spencer Churchill
Posted: Saturday, March 23, 2013 - 04:38 AM UTC
It's time for another update, There are four very shallow pin marks on the inside of the sail halves that need filling.
A little Mr.Surfacer and some light sanding did the trick. I also added the two brackets and the handrail to the inside of each half. The port side half also had the 'D' shaped platform for the torpedo sighting binoculars installed.
I did it his way because I feel it'll make things easier went it comes time to apply paint.
The following is a shot of the torpedo parts. They are the same ones included in Bronco's "SEEHUND" kit. They actually include some parts (on the smaller sprue to the left) that aren't used for the Type XXIII.
The torpedoes are very nicely detailed and it would be a shame to hide them inside the tubes. I plan on using just the warhead from one in the tube that is visible, and mounting a complete torpedo on the base. Lastly, I glued the rudder to one of the hull halves, rather than trying to trap it in place when gluing the two halves together.
You can also see one of the guards for the aft diving planes glued into place. Well, that's all for now.
Posted: Saturday, March 23, 2013 - 07:51 AM UTC
A couple of photos of the sail taped together.
I haven't come across any major issues with the fit of parts. The only omission I've come across won't really be that noticeable. The snorkel consists of two pipes, one for intake, and one for exhaust. So there should be two tubes leading down through the sail. Bronco only provides one. Also, the DF loop is retractable, so there should be a third tube for that. It's an easy fix.
The bracing between the tubes isn't prototypical, I added it for strength. Once the sail is assembled you won't be able to see much anyway. Just that there is something in there.
Posted: Monday, March 25, 2013 - 05:19 AM UTC
Hi AL,
Good work, coming along well. BTW did you see the PE update sets from Griffon for the Vosper?
'Action this Day'
Posted: Monday, March 25, 2013 - 07:21 AM UTC
[quote]Hi AL,
Thanks Alan, Making progress. I ordered two books to see what can be added, or corrected, if needs be. I'll check out that PE set, might be too late to use any of it though. Always seems that any add-ons come out after I've finished a build!
Posted: Monday, March 25, 2013 - 08:18 AM UTC
Looking great Al, I am really tempted to have a bash at one of these myself.
Posted: Monday, March 25, 2013 - 08:30 AM UTC
Thanks Simon, great kit, I wouldn't hesitate to reccomend it. But it is a really big sonnuvagun!
Posted: Monday, March 25, 2013 - 10:03 PM UTC
She is really taking shape beautifully.....Cheers mark
Posted: Wednesday, March 27, 2013 - 03:58 AM UTC
[quote]
Hi AL,
Watch them Al, I think they have your tea cup in the bonus set
Julian
Posted: Wednesday, March 27, 2013 - 05:56 AM UTC
Julian [Quote]
Actually, I think that tea cup is the only thing they missed! Looks like a great set if you're thinking of building a Vosper.
Posted: Thursday, March 28, 2013 - 08:32 AM UTC
I taped the two halves of the sail together to test fit it onto the hull.
I noticed a small gap at the very front, so I glued a shim of .030 plastic strip to each half.
This improved the fit very nicely.
Just to give an idea of the size of the beast, I took a pic next to it's smaller cousin, the Seehund.
Both subs carried the same warload of two torpedoes. As I mentioned before, the torpedoes are the same ones in both kits. Still waiting for my books on the Type XXIII to arrive. I want to see if more detail can be added to the bridge, as well as adding the outer doors to the torpedo tubes.
Posted: Thursday, March 28, 2013 - 08:48 AM UTC
Looking good Al, like the seehund too.
Attica, Greece / Ελλάδα
KitMaker: 16 posts
Model Shipwrights: 12 posts
Posted: Thursday, March 28, 2013 - 09:10 AM UTC
Looking good so far, i am building the same kit, the book has some drawings that might help you on the tower you just need to examine them very careful.
KitMaker: 673 posts
Posted: Thursday, March 28, 2013 - 09:20 AM UTC
Btw tea cup: ordered to get some inspiration - earl grey and that beast on the working bench
PS: there's no shop, which offers this special mug, but there are shops to "build" your mug if you send a photo and the artwork for lettering...
Posted: Thursday, March 28, 2013 - 09:33 AM UTC
Hello Simon, the Seehund was a pleasure to build, and the Type XXIII hasn't given me any headaches so far. I wonder what Bronco might come up with next?
Posted: Thursday, March 28, 2013 - 09:35 AM UTC
Thanks Thomas, good to know, the tower would be one of the focal points and any additional detail will help.
Posted: Thursday, March 28, 2013 - 09:37 AM UTC
Hello Michael, not much of a tea drinker, but I like the mug.
KitMaker: 673 posts
Posted: Thursday, March 28, 2013 - 09:53 AM UTC
Yes, very helpful drawings! This drawings published in "Vom Original zum Modell" are also available in DIN A1, but i think you can scan and scale them (or parts) up to do some improvements to Bronco's boat. There's a little bit more inside the tower - not only Schnorchel and periscope...
And Bronco's Seehund was an easy kit to put into a small diorama of Ijmuiden harbor. Let's wait for Bronco's next seagoing vessel in 1/35. A Kriegsfischkutter would be great...
KitMaker: 673 posts
Posted: Thursday, March 28, 2013 - 10:14 AM UTC
Hi Al,
there's a very special drink at the german northsea coast called "Pharisäer" (pharisee). An old tale tells the story of a priest fighting his own little war with his community, for they are drinking a lot all over the day. So they find her own way to dupe the priest. They had a lot of rum in their coffee, but stopped the nice smell with whipping cream on the top. But some day the priest - as a guest on a marriage and proud of his abstinent lambs - took the wrong cup... Shouting out loud: "Oh you old pharisees"
Maybe that drink is better than earl grey... I will test tomorrow!
Posted: Thursday, March 28, 2013 - 12:28 PM UTC
Prosit!
Zhejiang, China / 简体
KitMaker: 67 posts
Model Shipwrights: 58 posts
Posted: Thursday, March 28, 2013 - 05:59 PM UTC
There are a few issues with the kit as you've undoubtedly discovered but overall its nice. You will find lots of info plus some great photos over on the Sub-Driver forum by David Merriman as he builds his RC prototype.
http://forum.sub-driver.com/showthread.php?2158-Bronco-Type-XXIII-in-1-35th-scale"China is a sleeping giant. Let her sleep, for when she wakes she will shake the world." ~ Napoleon Bonaparte
Posted: Thursday, March 28, 2013 - 11:34 PM UTC
Hello Charles, thanks for the link, I'll have to check it out.
