Hi Gunny
I am all ready to slap on some paint for Dreadnought project.
I will take some pictures before I do it.
I still have all my superstructures separate etc. but I am wondering how you go about painting your ship projects.
In particular the hull and then the deck. The deck on mine appears to be mostly timber interdispersed with steel structures. I am a little unsure how to attack this.
Do I spray my hull grey then my deck timber and handpaint the greystructures situated on the deck?
Or spray it all grey and hand paint in the deck?
The superstructures and guns etc I can paint separate its just the deck/hull area I am unsure of.
I know this is a pretty basic question but some help for an old armour modeller before I start might make it all more easier.
Thanks.
Hi Sean!
Glad to hear that progress has been made on your entry, mate, but now things are going to get a little tricky for you...I paint as I go, meaning, I finish the lower hull first, then build the upper deck, finish paint the deck, attach the deck structure to the lower hull, and then proceed to build my superstructures and paint these before I attach them to the upper decks...(only after dry fitting each and every part to make sure the fit is good!) the point where you are now, is going to need a good deal of handpainting...if I were you, I would paint the upper deck first, (if you are spraying), mask it off well, then spray the lower hull...then you can proceed to either hand paint the superstructures, etc, or you can mask off the lower hull (if need be) and spray the superstructures (while the deck is still masked).
Hope this helps ya out some, Sean, and looking forward to seeing some photo's of your build!
