It may not look as though I have been doing much from the pictures, but I am putting in at least a few hours each night, and some things seem to take forever!
First up, the searchlights are finished except for the silver to represent the lens. That can wait in case I need to paint them again.
I have also;
- Assembled and cleaned up the two funnels ready for PEing.
- Painted the boat deck.
- Assembled various other parts like the anchors.
Then we come to some PE assembly.
This is a small platform that holds a range finder I believe. Don't worry about the seemingly out of alignment railing, when the glue is dry I will persuade it into its correct position.
Then we have the Admiral's Walk..
This took quite a while as only the two inner railings had any clues as to where to bend it. The outer railing had nothing and some of the corners needed rounding which always takes longer. The back of the outer railing has not been glued as yet as I wait for the rest of it to dry first.
That's it is for the moment.
Warren
parts
