Looking good Russell, Thomas and Simon.
Thomas, I was not implying anything when I answered your railing glue question. I didn't see until later that you asked the PE Gods to help you and I ain't one of them!
OK. I have been busy but haven;t really had that much to show for all the work. Currently at the stage where you are putting lots of fiddly bits together.
First up, I was considering whether or not I really needed to make 12 searchlights from resin and PE as supplied by Pontos. Preparing resin parts has always been seen as a pain to me with their massive pour stubs and the necessary cleanup when it is removed from the part, but after I put one together I had to do them as it is chalk and cheese..
Each searchlight is made up of two resin pieces and one PE part. They don't mention the clear part supplied by Zvezda for the lens but I am going to try and use it. The two resin parts look like this after the 'massive pour stubs' are removed..
Then I glued the two parts together and took a few piccies with the Zvezda one for comaprison purposes..
I think you can see why just from these few photos why I need to use the Pontos lights..
Over the past week or so I have also been working on the gun turrets and finished them today.
Well maybe not.. the macro lens on a camera seems to highlight all the faults in any part and that bare brass bit is not good enough I say!!
Oh well, a touch of paint and it should be fine.
That's it for now
Warren
