Trumpeter North Carolina, WEM PE set. See My Gallery for kit pix ...
I've been working, but not very fast 'cause I've got some other things going on (wife demands I finish the 1:1 scale deck furniture, friends coming to visit, etc).
I had hoped to reach a point by now to post some pictures but I'll just give an update & do pictures later when I finish this step.
I got what I needed for the display base & that allowed me to drill some mount holes in the hull and build a working board to hold the hull during work.
If you saw my original post in Campaigns, you'll know I found an issue where the upper & lower hull did not match.
I cut the bracing bars in the upper hull, fitted the upper hull carefully to the lower hull, then rejoined the bracing bars with strips of Evergreen, then glued the upper & lower together. I have put a light coat of filler where the upper & lower hull meet & expect to sand that down this weekend. I also want to cut off the boat hooks molded onto the rear hull & replace them (later) with detailed pieces.
I hope to have pix this weekend that will show the before & after of the hull work.
Next step will be to mount the 3-piece deck to the hull & fill the join between sections -- that looks like lots of work to preserve detail, etc ... Also want to work under the hull so I can get to painting the hull & deck ...
I haven't finished my review of the kit & the WEM PE to mark up what I will replace -- I am focusing on the deck so I can scrape off things before I mount the deck to the hull.
Update -- just got some extra PE from Gold Medal, ladders, doors, etc & have to work that in to the plan.
As I said earlier I have some other things going on, but I'm also trying to start on the above deck stuff -- first effort will be the 16" turrets, then the 5", and the structures. All ladders will be replaced, all detail will be worked, I just have to get this to be #1 project among several.
Whew !!!! Lots of talk, no pix
I'm in it, just not on schedule ....
John
