Well the funeral is over. Memories remembered. But I still have this bloody virus that doesn't want to go away.
But enough of all that. I have got some stuff done over that past week or so and I thought I would share it with you.
I am now building the 4 in Gun and it's associated paraphernalia that sat on the foredeck of the Corvette and made submarine's lives a real pain in the butt if they were on the surface. First up are the stanchions that hold up the wires running around the edge of the stand..
Two pieces laminated together then the attaching bracket attached to the base. The holes for the wire had to be drilled out as well.
Then we have the same stanchions and the two ladders that go on either side of the stand..
Each of the ladders is in lots of pieces you need to assemble. I use CA glue rather than solder here.
Next we have the stand itself. First up you need to attach its support underneath..
Notice the solder around the edge were I attached the edge of the stand. Not too hard if you have a nice big soldering iron and some of the solder paste.
Some more details of the stand..
Here is the stand with the wire mesh surround installed. I put it in place with CA glue..
Then I sprayed it the RB White colour then masked it up and sprayed the grey on the deck of the stand..
It is still wet in that picture. This morning I removed the masking..
Next up I need to attach the stand to the foredeck then I need to manufacture and attach 36 of these..
That is a 10mm square it is sitting in so it gives you some ides of the size. This could be some PE that will finally stop me but we will see how the next few go. Or I might be lucky and find the 3D printed ones I saw earlier..
cough, cough.. gurgle, sniff..
Warren
