cloggerdemps
Australia
KitMaker: 88 posts
Model Shipwrights: 75 posts
Posted: Wednesday, December 02, 2015 - 11:36 AM UTC
Looking good!
warreni
South Australia, Australia
KitMaker: 5,926 posts
Posted: Wednesday, December 02, 2015 - 11:50 AM UTC
Looking good!
Thanks Colin.
How did you end up attaching the roof to the rest of the bridge? I am thinking Araldite will do the trick. Bit hard to solder to plastic..
cloggerdemps
Australia
KitMaker: 88 posts
Posted: Wednesday, December 02, 2015 - 12:22 PM UTC
Not sure what you mean by the roof? I think I glued the bridge to the lower cabin with expoxy resin before gluing the complete assembly to the deck. Hence I used locating wire for the 3 front posts going into the deck. Plus I tired using masking tape to help line up the lower cabin with markings on the deck.
warreni
Posted: Sunday, December 06, 2015 - 12:59 AM UTC
That is how I thought to do it.
I must not fall into the 'hurry it along' trap. This is the longest build I have ever done by a long way.
cloggerdemps
Australia
KitMaker: 88 posts
Posted: Monday, December 07, 2015 - 02:03 AM UTC
I used epoxy resin for some large deck fittings such as the funnel assembly as well. I found the epoxy seals the join line nicely. Although it can be difficult getting a sharp 90 degree between the assembly and the deck. I would wipe excess epoxy away, but over time a little would seep under the join. My deck under the funnel area was not completely flat (owing to deck PE's not lining up perfectly) so again the resin would fill in any potential gaps.
Posted: Wednesday, December 09, 2015 - 02:35 AM UTC
Nice work on the front of the Bridge mate,
That is some lump of etch.
JJ1973
#345
KitMaker: 1,835 posts
Posted: Wednesday, December 09, 2015 - 10:13 AM UTC
I fully agree with Si,
very nice work on your bridge Lots of brass and lots of soldering - haven't done that in an eternity, I wonder how my soldering would look like. Well, I don't really want to see...
Great work, looking forward to see your bridge in place!
warreni
Posted: Wednesday, December 09, 2015 - 10:58 AM UTC
I will overcome any problems with brute force if necessary..
warreni
Posted: Wednesday, December 09, 2015 - 11:00 AM UTC
Thanks mate.
No where near as big as the forward deck piece Si... luckily!
Warren
warreni
Posted: Wednesday, December 09, 2015 - 11:02 AM UTC
I am sure it would be fine Jan.
Will get it in place asap.
Warren
warreni
Posted: Friday, December 11, 2015 - 12:40 AM UTC
He's baaaa-aaacck..
Not heaps of progress but a little bit of bending etc.
First up the floor of the bridge keeps getting parts added..
The strip of brass you see under the planking had to be curved and attached
Sorry but the piccy I took of the strip alone didn't turn out too well, but you can see it in this overall shot,
Then the 'wooden' planking bit gets attached to the top of the strip. Then this little box has to be bent up and attached..
I soldered the edges together. Easy to do with such a small item. Then it gets attached to the raised wooden centre bit..
Like so. Then one of the plastic kit parts gets attached to the middle of the box. Havrn't seen it yet but it very unusual not to have a cast piece for the spot.
And that is it for this update. Lots more to do over the weekend hopefully. Have to go and have a look at some photos to see the colours in the area as there is some painting to do before I attach that raised deck area.
Cheers for now
Warren
Posted: Friday, December 11, 2015 - 07:07 PM UTC
Nice small progress Warren.
Would I be right in assuming the compass binnacle sits on that brass box.
Cheers.
warreni
Posted: Saturday, December 12, 2015 - 12:10 AM UTC
Cheers.
That is a very large possibility my friend...
Warren
warreni
Posted: Saturday, December 12, 2015 - 03:11 PM UTC
And thus it came to pass that another day of modelling (well a few hours anyway) came to an end just before 6pm and dinner.. Mushroom, Onion and Cheese Scrambled Eggs.
I concentrated on the upper bridge deck (as I did yesterday) and got quite a bit done.
First up were the speaking tubes dotting the open bridge..
Please also notice that the rest of the things have been attached to the bridge bulkhead, The door on the right leads into a tiny room which the window lets light into. The locker on the right needs a bit of a touch up by the look of it. Notice also that the compass stand has been painted.
Then I bent and soldered the two search light decks at the rear of the bridge deck.
And yes, that is supposed to be green anti-slip, aka Semtex (I thought that was an explosive).
Then we have two brass coloured thingies.. parts of the compass system if I am not mistaken. Not finished yet as I am sure the squat one needs more detail painting not called out anywhere.
Anyone know where I can find a colour piccy of one?
Unfortunately one of the delicate pipe rail thingies didn't survive the journey. Hopefully its untimely demise will be covered by the extra set of these items I bought.
And then we have a complete one being painted..
Lots of rust opportunities with these which I won't be taking with this model as it is to be a museum model. I have another in the cupboard for the weathered one..
Then I started making the searchlights for the searchlight decks. You take all these parts..
Glue the shutters on the lights..
Then attach the brackets to the smaller lights..
.. using my bending blade to support the brackets while they dry..
And sometime tomorrow I will glue the light to the top of its stand.
And that's it for today. The cast parts normally take a bit of clean hence why the speed of the build is slow. I suppose all the details don't help.
One thing that is missing is any detail in the wheelhouse.. I have no idea what goes in there, size wise, and I don't think I have the skill to build a 1/72 ships wheel... so hopefully it won't be too noticeable when it is finished..
Cheers all
Warren
cloggerdemps
Australia
KitMaker: 88 posts
Posted: Saturday, December 12, 2015 - 04:25 PM UTC
I didn't think it was necessary to worry about the wheelhouse interior as it wouldn't be open to view.
Looking good as usual!
rolltide31
#377
KitMaker: 1,481 posts
Posted: Saturday, December 12, 2015 - 06:29 PM UTC
Warren,
Really incredible work. Its a real joy to watch as you progress through this build. I have never really worked with white metal parts as they scare me but you make it look easy
Thanks for sharing.
Posted: Sunday, December 13, 2015 - 12:41 AM UTC
Looking good Warren,
The magnetic compass binnacle, the one with the ball on each side, the bit below the dome was usually wooden, so could be wood, or painted grey, the dome would be brass, the "arms" the balls sit on could be brass or grey, the balls which are steel, to help counteract the ships magnetic field, were red on the port, and green for starboard.
The gyro repeater would normally be grey, might have a brass dome.
Hope that helps
cloggerdemps
Australia
KitMaker: 88 posts
Posted: Sunday, December 13, 2015 - 02:06 AM UTC
I thought the gyro repeater was a pelorus. I sliced the top in half to leave a flat surface.
Posted: Sunday, December 13, 2015 - 03:22 AM UTC
Hi Colin,
Good call, could be a pelorus, but I from memory, I don't have my AOTS on the flower class to hand, they did have a Gyro repeater on the bridge.
The only possible difference from the painting point of view, the cover on a pelorus would be grey.
Nice idea, flattening the top and showing the compass card. Love that sort of detail, adds real depth.
Cheers.
warreni
Posted: Sunday, December 13, 2015 - 10:23 AM UTC
Thanks Colin.
warreni
Posted: Sunday, December 13, 2015 - 10:24 AM UTC
Warren,
Thanks for sharing.
Only way to learn how to work with something is to work with it..
Jump right in Dave, you will be fine. Diecast metal is soft and easy to work with.
Warren
warreni
Posted: Sunday, December 13, 2015 - 10:25 AM UTC
I think I will just use the kit bits and detail them with paint..
Thanks though
Warren
Cosimodo
#335
KitMaker: 1,808 posts
Model Shipwrights: 871 posts
Posted: Sunday, December 13, 2015 - 11:52 AM UTC
It's looking superb Warren. An amazing effort with that level of detail.
warreni
Posted: Sunday, December 13, 2015 - 02:28 PM UTC
Thanks Michael.
And now for a very quick update..
The smaller of the two sets of search lights on their supports, and..
Yes, I have installed my first pipe rails! One word of warning with these.. they are pretty delicate so make sure you buy enough to cover any breakages.
That's it!
Bye for now
Warren
Posted: Monday, December 14, 2015 - 02:35 AM UTC
Ahoy Warren
Nice work indeed thus far.
FYI I have a 1/72 ships wheel going spare you are welcome to have.
Its spare from my E-Boat its fairly generic looking and you are welcome to use it.
I am more than happy to contribute it to this epic build.
Just let me know.
