That would be awesome Sean. But I will have to give you something for it.
Thanks mate
Warren
warreni
KitMaker: 5,926 posts
Posted: Monday, December 14, 2015 - 02:46 AM UTC
Posted: Monday, December 14, 2015 - 10:37 AM UTC
Wow, not quite a week away from the desk and you again produced some great updates
This is really some great looking work, and yes, lots of brass and metal of all kinds. Set up of your voice tubes and the fragile bars look excellent.
As for the compass color question, I fully agree with Si's recommendation!
warreni
Posted: Monday, December 14, 2015 - 10:49 AM UTC
Thanks for encouragement Jan.
Hope the finished product lives up to your standards.
Warren
Warren
cloggerdemps
KitMaker: 88 posts
Model Shipwrights: 75 posts
Posted: Monday, December 14, 2015 - 02:36 PM UTC
Warren, will you be painting the deck and stanchions together? I had to paint the deck first (in oils) before fitting the stanchions as I thought this would be easier. Its fascinating seeing how other modellers approach the sequence of assembly and painting.
warreni
Posted: Monday, December 14, 2015 - 03:35 PM UTC
No oils for me Colin. Just acrylics. Yes, the decks are all painted before I attach the stanchions etc.. which i wll also be pre-painted. Then I just need to touch up any rough bits.
I will report back when I have attached the upper deck Sir.
Warren
Posted: Tuesday, December 15, 2015 - 03:43 PM UTC
Wow Warren! Pipe Rails! At this scale! You are a brave man!
warreni
Posted: Sunday, December 20, 2015 - 01:05 PM UTC
Wow Warren! Pipe Rails! At this scale! You are a brave man!![]()
Yep, braver than you will ever know..
Thanks Russell for that undeserved comment. I don't know about brave but you have to be very. very careful cleaning them up as they are so delicate.
Anyway, after a weekend of computer problems I am back on line and have a bit of an update.
First up, does this look right Si?
I hope so. After I finished the sticky-uppy bits on the bridge deck I started on the two wind deflectors. These were mounted on the front of the bridge either side of the part with the windscreen. The first thing I did was bend the first one the the wrong way. After moving it a few times it snapped off. Great I thought.. I then repaired it with a bracket and some solder and got it lined up really nicely, and realised it was still wrong!! I had to desolder it and try again., this time I got it right. You can see the old solder on the deflector on the left.
And a few more shots of these complex items..
And upside down..
Then I took a bit of break and soldered and glued a couple of lockers for the bridge..
Then the instructions asked for the running lanterns to be installed. I used Araldite for these.
Oh and look it looks like it has drooped a little. Marvellous. And here is a look at the front of the bridge with its first coat of paint, and sans the wind deflectors.
That's it for now. More progress over the Christmas Holidays!!
Warren
cloggerdemps
KitMaker: 88 posts
Posted: Sunday, December 20, 2015 - 05:18 PM UTC
Great work. Re: wind deflectors. I gave up after the first attempt and decided to reorder a second set and start again. A very challenging exercise. Wait until you start the depth chargers racks!
Posted: Sunday, December 20, 2015 - 06:21 PM UTC
Warren,
Its always a joy checking out your updates and seeing your very impressive PE work. Can't wait to see your corvette come together
GrantGoodale
KitMaker: 99 posts
Model Shipwrights: 99 posts
Posted: Sunday, December 20, 2015 - 08:20 PM UTC
Warren -
I am in awe of the quality of your work.
warreni
Posted: Sunday, December 20, 2015 - 11:57 PM UTC
Warren,
Thanks Dave
Hopefully it will come together sooner than later!
warreni
Posted: Monday, December 21, 2015 - 12:00 AM UTC
Warren -
Hi Grant.
You must be easily awed then..
All you have to do is take your time and anything can be done.. if not throw dollars at it until the problem disappears.
A good example of this are the shackles I accidently melted trying to remove some super glue. Did you know diecast metal has a very low melting point? Anyway, I found an ad for 1/35 shackles that look perfect for this job.. and they are brass so they won't melt..
Thanks again Grant
Warren
warreni
Posted: Monday, December 21, 2015 - 12:02 AM UTC
Oh thanks for the good news Colin (sarcasm)
The only problem I had was self inflicted when I bent the original one the wrong way.. three times..
Thanks for the encouragement though..
Warren
MadModeler
KitMaker: 454 posts
Model Shipwrights: 5 posts
Posted: Monday, December 21, 2015 - 08:41 AM UTC
Hey guys... I love read this post. If you need a hand, HMCS Sackville is just across the harbor from me. I can snap some pictures if you need them. Keep up the good work.
Tom
Tom
Posted: Wednesday, December 23, 2015 - 12:28 AM UTC
Hi Warren,
The bridge is looking great, the voice pipes and the binnacles are bringing it to life.
Looking forward to seeing more progress.
warreni
Posted: Wednesday, December 23, 2015 - 12:44 AM UTC
Tom![]()
You luck bugger.
I do have a few photos I would like but there is no real rush at this minute. Some good ones of the wheelhouse would be handy.
My next build may just be HMCS Sackville..
Cheers and thanks mate
Warren
warreni
Hi Warren,
Thanks Si
warreni
Posted: Thursday, December 24, 2015 - 12:12 PM UTC
Ho ho bloody ho...
Merry Christmas to all and hope you have a great 2016.
Now that's out of the way it is down to business. Having a very quiet Christmas means I got a few hours at 'The Bench' today, and here are the results of my labours..
First up I painted the front of the bridge again, with the airbrush this time, and a few bits and bobs..
A flag locker which WAS one of the most difficult things I have built..
Uprights still need to be painted. Then I painted the following bits..
Then it was time for the direction finder on the front of the bridge..
I had a couple more of the DF but they were not too good so I didn't bother with them.
That's it for today.
Warren
Warren
TRM5150
Posted: Thursday, December 24, 2015 - 06:24 PM UTC
Merry Christmas Warren! All the best to you and your family today! I hope you are enjoying the day so far!
I am still set back with your work on this one! Just some solid modelling all around! Keep enjoying the journey!
cloggerdemps
KitMaker: 88 posts
Posted: Friday, December 25, 2015 - 02:06 AM UTC
Happy Boxing day!
V neat work as usual.
Have a great and productive 2016.
Posted: Friday, December 25, 2015 - 10:26 AM UTC
Very nice Warren
good to see you trucking on during the festive season and not giving in the the heat
Merry Christmas and happy new Year everyone!
warreni
Posted: Friday, December 25, 2015 - 12:30 PM UTC
Happy Boxing day!
Thanks Colin.
warreni
Posted: Friday, December 25, 2015 - 12:31 PM UTC
Very nice Warren
good to see you trucking on during the festive season and not giving in the the heat![]()
Merry Christmas and happy new Year everyone!![]()
Heat gets a bit high I just walk over to the button on the wall and press it, A few minutes later the house is cool..
Cheers Russell
Warren
Posted: Saturday, December 26, 2015 - 02:17 PM UTC
Quoted TextVery nice Warren
Cheers Russell
Warren
hehe-that would be the same 'button' i refer to mate, but sometimes it just gets so hot, that not even that works
The man cave (garage) doesn't have one of those 'buttons' either-so no painting
warreni
Posted: Saturday, December 26, 2015 - 02:34 PM UTC
Quoted TextQuoted TextVery nice Warren
Cheers Russell
Warren
hehe-that would be the same 'button' i refer to mate, but sometimes it just gets so hot, that not even that works![]()
The man cave (garage) doesn't have one of those 'buttons' either-so no painting![]()
You have to walk all the way out to the garage to do modelling? That was a bit short sited my friend.. My hobby room (no man-caves for me. Only nut jobs live in caves.. oh and people in Coober Pedy) is right next to the kitchen where the fridge resides.. and the freezer and the pantry and near a toilet.. I think you get the idea..
Finished the bridge supports today. Painting and more photos tomorrow.
