Quoted TextWow! Fantastic build, Jan.
Can only hope mine's half as good as yours.![]()
yes, you're right about the prop shaft holes in the hull. Not sure what to do about that yet...
Re the prop shafts, I presume the holes are too big and the shafts too small? Easiest fix is to just glue them in place then fill the gaps with a little CA. Or I have also used white glue successfully.
Good work so far mate. The Pontos set should be interesting, because the instructions are not renowned for their accuracy..
Cheers mate
Warren
Thanks Warren!
Good to hear from you! How's Adelaide treating you? With the prop shafts, they are not truly round, so there is a gap-a concession to being able to tool the hull without sliders. Normally i'd just fill the gap and spray over, but usually i'll leave prop shafts off till after painting then fit them... Look like i'm going to have to break that rule
Actually using the WEM PE set, so no probs with instructions mate, but Joseph has generously offered his Pontos catapult which he won't be using in his build-so a bit of both
